Can I put different code files together in 1 dynamo file?
I have 3 separate dynamo files that work fine but I want to put it together so i don’t have to run them separately.
and this without opening copying it manual, if possible.
Hi @giel.lambrechts not sure you wanna loop them one by one ? if so Orkestra can do it with "Playlist tool "
Or Bird Tools “Dynamo Multiplayer” ![]()
https://www.birdtools-developers.com/dmu.html
I have 3 dynamo files and I want to play them after each other with 1 click (just once). Is this something you can do with Orkestra?
perfect
I will try
its works perfect thanks for the help.
I also found another instances that works to, its called NonicaTab
Great ![]()
