Can i implement a sweep blend with dynamo?
The image on the right shows a ditch placed by creating a family using sweep blend.
The image on the left shows a ditch placed using the solid.byloft node in dynamo.
I would like to implement the functionality of sweep blend using dynamo without creating multiple cross-sections using loft.
Looks like an adaptive family is what you really want (giving you parametric control in Revit), but ‘Solid.ByLoft(profiles, guideCurves)` should give you what you need.
Thank you, I’ll try it
