Hello there:
Whats the last part of the script, would you share it?
And one more question, this works for an alignment in civil 3D right?
Im new using dynamo, thanks in advance!!
@mzjensen Hi! I’m coming here as a last resource
I have used some nodes from Camber 3.0 in a program I made a while ago, but they are still very helpfull nowadays.
The thing is that it works on my computer but not at work. I’ve tried several times to reinstall the package but it seems like the nodes I used were removed from the same version I used before. Also tried to install some newer versions but couldn’t find the nodes there either. The nodes I’m talking about are: PressureNetwork.Fittings, PressurePart.Connections, PressurePart.Solid, PressurePart.Data, PressurePartConnection.Position.
What can I do? Is there any other version with these nodes? I know this version is very out of date but we work with Civil 3D 2021.
Hi @marjorytavares,
Which version of 2021 specifically? You’ll need 2021.3 at a minimum.
Oh, it must be the issue! Because on my computer is the version 2021.3.6, but at work is the first release I guess, I’ll see if we can update it. Thanks for the quick response!
Is there a way to get the geometry for polylines from an object of type “external object”?
Is there a way with the Camber Package to import a layout AND the viewport(s) associated with the layout tab in an external document? I have been successful in bringing in a new layout tab from an external file, but it doesn’t bring any of the associated viewports, references, etc with it. I am trying to find a way to get a file with a bunch of layouts and viewports separated out into different files with just groups of 5 layouts (or so) per .dwg. I am really struggling with this.
Please create a new post with you specific need and and your graph and we can have a look at it.
I’ve browsed the Camber Package and wanted to ask; Is there example dataset to understand how the nodes work together for certain functionnality ?
Was looking forward onto trying to label structures and pipes in Profile views and plan.
TIA
Hi I am having issues with a Camber node, would you mind checking out my thread? Camber External Layout Not Working
Maybe I’m misunderstanding out External Layouts work compared to internal layouts but I figured it was the same thing, external just lets you make it from outside the file…
@mzjensen Thanks for the Camber package, I’ve only really gotten into it but it’s fantastic so far. One question/comment, is it possible to have no marker for civil 3d labels?
I can create a label that does not display the marker, but it would be preferred to beable to use the native options.
Jordan
Hi @JBroad,
Have you tried just passing in null for the marker style? You can do that in a Code Block. Can’t remember if that will work or not.
Thanks for the response, unfortunately passing a null for the marker style does not work. As I noted there is a workaround but it would be good if we didn’t have to do that.
