Is there a way to call a parameter from inside the Imperative code block?
When I have an x parameter outside the Imperative(like below) I can get the Input entry in the Code Block Node but the imperative does not recognize x.
If I put the x parameter inside the Imperative Code Block I can’t get the Input entry. Thanks…
x;
geom = [<span style=“color: #8c5eaa;”>Imperative</span>]
<span style=“color: #8c5eaa;”>if</span>(x><span style=“color: #2585e5;”>3</span>)
<span style=“color: #8c5eaa;”>return</span> = <span style=“color: #8c5eaa;”>true</span>;
<span style=“color: #8c5eaa;”>else</span>
<span style=“color: #8c5eaa;”>return</span> = <span style=“color: #8c5eaa;”>false</span>;
