Imperative Blocks
Is it possible to set a Revit element parameter within an imperative block?
I’m trying to use an If else statement to say:
if the name of this element == a
then set parameter value to b
else if
the name of this element == c
then set the parameter value to b
can this be done with DS?
thanks
This may be wrong as I am typing design script on my phone while riding the train, but it should work if you type it out and correct any typos (which may be numerous).
Elem.Name == A?
Elem.SetParameterByName("Parameter Name", B:
Elem.Name == C?
Elem.SetParameterByName("Parameter Name", D):
null;
Elem is the element list, A is the first value to test for, B is the desired parameter value, C is the second test value, D is the second parameter. Any object with neither A nor C name values has no change to the parameter value (hence the null).
Hi Jacob,
Thanks for your help.
Here’s my first attempt at setting parameter values from within Imperative blocks:
This is going to save me a lot of time (and nodes!)
PS excuse my silly parameter values :smiley:
They are super useful. Glad to have helped.
And as far as parameters go, I have seen sillier. :slight_smile:
