CAD to Revit piping with fittings
Hi here are all files I used DWG RVT DYN
https://drive.google.com/drive/folders/1z_PpUNxJX4eqLDb-Uizt5xAOUO0_5aAh?usp=sharing
thank you
did anyone get a solution for me?
how can autosprink read CAD files and convert to pipe
Great question for autosprink, I haven’t used it before so I can’t tell you what it does never mind how.
Because you are using pipe types it will be a Tap ore a Tee not a mix. This has to do with the way Revit handels the pipe types. Tee makes form 2 pipes mainly 4 parts 3 pipes and 1 Tee. Well a Tap would make 3 Part, 2 Pipes and a outlet. You could change the behaver if the taps where different CAD layer types and assigning this to a other Pipe Type.
Assuming you used those parts of my script. :wink:
Good luck, AutoSPRINK - Fire Sprinkler Design Software
Hello Sir… Good day to you…
I want to use your dynamo script, but it shows some error in
  1. List.GetitematIndex-“Warning: List.GetItemAtIndex operation failed.
    Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index”
  2. PipeBy Lines-“Warning: List.GetItemAtIndex operation failed.
How to solve this one sir… Please help me…
Hi can you please share a screenshot of the script
did you install the packages required for this script
Programmability with AutoLISP was a big reason for AutoCAD’s popularity. We could get our own customization done without having to wait for the app’s developers like the competition (E.G. ComCode). Nowadays, that brilliance has trickled down to Dynamo with a similar effect.
You may try this logic for joining each element to the next one:
