CAD polylines to separation lines
Hello !
I’m trying to create room separation lines from a CAD drawing. I’m using some BimorphNodes to get the cad lines into Dynamo and Revit, but I didn’t get to work the Clockwork node “RoomSeparator.FromCurve”.
Has anyone worked with this node ?
Thanks for your help !
Philipp
What is the error message?
it gives me this message:
Warning: __ func_c68c079965c342f4b8ba93a248013d35 waits for the argument type (s) (Curve, SketchPlane, var … ), but has been called with (Revit.Elements.ModelCurve , Revit.Elements.Level, Revit.Elements.Views .FloorPlanView).
so I guess, i m not “feeding” the right things into the node
You can try this:
Don’t know if passing a level instead of an actual sketch plane will work either.
Edit: You do need to provide an actual Sketch Plane:
Thanks a lot for the advice, it worked !
For the plane I came up with a slightly different solution. Understanding your graph I could do without all the BimorphNodes stuff in the beginning.
CADPolylignesVersLignesREVIT.dyn (24.2 KB)
