CAD.CurvesFromCADLayers - problem
Hello
I have a problem with BimorphNodes.
CAD. CurvesFromCADLayers problem: Warning: CAD.CurvesFromCADLayers - Operation failed.
You cannot cast an Autodesk.Revit.DB.FamilyInstance type to an Autodesk.Revit.DB.ImportInstance type.
List.Flatten problem: Warning: List.Flatten - Operation failed.
BimorphNodes version is 3.0.3. Everything worked fine with the old version of BimorphNodes, i dont know the version. Today i had to download the new version of Rhythm and BimorphNodes because the old ones disappeared and i had a unresolved text on it.
Import3d2Pipe.dyn (29.0 KB)
Do you have the linked file as rvt or as dwg? You should have it as linked dwg. Otherwise would not work.
Thank you so much.
Best regards
Skoupil Jakub
