I would like to extract the CAD Color from the layer that was created from BiMorph. I am not much into python coding as much as I know I should be but was wondering if there is any way to do it without coding?
I have tried a few things for you but I couldn’t find a solution with custom nodes so I had to do it in Python.
What my graph does is, it reads the name of the Category of the linked CAD file. Then my Python node searches for the corresponding ImportedCategory and its Subcategories (Which have the same name as the CAD Layers). Then it creates a Dictionary with the name of the layer en the Dynamo Color. You can then use the BiMorph node to see which Layers are actually used and query the color of that layer from the Dictionary.
I hope this will help and if you have any question, let me know!
This will totally work for what I need it for! So, what I plan on doing is taking it 1 step further. So I am going to have my AutoCAD file colors, determine the lineweight for the detail lines. For example, Red may be lineweight 4 vs Yellow at Lineweight 2. I just could not figure out a way to read the AutoCAD colors for the extracted data. Thank you so much and hope you have a wonderful holiday season!
Are you going to detiremine the Line weights based on the colors? Because you can also query the Line weight and the Line Pattern from the CAD File. ColorsAndWeightFromLinkedCad.dyn (20.1 KB)
This is pure gold! I noticed from the icons that I believe this script works for 2.6 Dynamo. I am currently running 2.1 and got the following error when it came to the dictionary. It seems the python code is coming back as Empty Dictionary and not entirely sure why. I tried it both on a CAD Link and CAD Import method. Any idea?
This is quite phenomenal. I’ve been searching for a way to pull color information from AutoCAD layers for months and I just happened to come across this post today.
I’m able to get it to run, but I get an empty dictionary output from the Python script just like the OP was. I don’t really know much about python scripting, but I’ll try running it by my BIM Manager who is a real whiz at this sort of thing and maybe he can figure out what we’re doing wrong.
is selecting “KeynoteTable” and “AssemblyCodeTable” id’s, not the Import Instances that are present in several views, nor the one I selected in the Active View. Since it’s not selecting any Imports, it stops at the first IF. This causes the script to return an “Empty Dictionary” which is causing others’ issues.
-EDIT-
It appears this only works with Linked DWG’s, not Imported DWG’s, this is a distinct difference. Additionally, the line above only returns linked DWG’s in 2019 and above, not previous version.
Finally, there is another issue specific to Revit 2019:
'string' does not contain a definition for 'Key'
This is because pre-2.3 versions of Dynamo cannot handle Dictionaries properly. I’m still digging how to remedy this.
I didn’t try it for Imported DWG’s because we get a slap on the wrist if we do that, gives you alot of junk in the project ;).
I only put the output in a dictionary so it was more organized, but for pre 2.3 versions you gave a good example for with the lists. Nice to see that you left your versions aswell! Does your work for imported CAD files?
I agree that import is undesired, though it was necessary for a very specific workflow that we were trying to abandon; the reason we were using this graph.
A layer can only ever be one color at a time. Certain lines or blocks within detail groups can be overridden to be other colors while still being on another layer, however.
One way you can fix this is to set the color of everything in the drawing to “By Layer” and burst/explode anything that doesn’t conform to layer color settings after that. If you wanted to maintain the color overrides rather than go by the layers, you might be out of luck. That would probably require modifying the code to look at each element in the DWG and outputting a list that you can then filter to just the unique colors, but there can be tens of thousands of lines in a given background depending on the discipline and that’ll bog down your model significantly.
