When I create cable tray with service and add cable tray fittings, I must do 2xTAB+Click to select all line and put all in the same service type.
Can I do that with dynamo ?
Or if I select just one cable tray, then put all line others cable tray with fitting and cable tray fitting in the service of the first select
Daniel OLIVES
WSP France
to get you started: There is a node in MEPover package called “Elements in connected network”. With that you can input a single cable tray and it will give back all the connected elements in its network.
Thank’s you very much, i find a solution
Daniel OLIVES
