Cable Tray By Line Not Working
On revit, Why cable tray is view blue line?
thank you in advance
That is the geometry preview of a line. Please post a new topic including all content required to reproduce your problem (.dyn file, rvt file, etc) and someone will likely help you solve your current problem.
Why can’t I see the cable tray and looking as a blue line?
Please post the dyn and rvt files. A preview on the CabeTray.ByLines node would also help.
Warning as follows “Sorry, new users can not upload attachments” :slight_smile:
Try another file sharing service like google drive, onedrive, or similar. :wink:
CableTray.ByLines.dyn (27.0 KB)Test.rvt (1.2 MB)
It works perfectly.
The only thing you have to do is replace CableTray By CableTraytype in Element Types.
thank you for your interest
I did and similar result
The node in red is because you didn’t install the MEPOver package and therefore you don’t have the custom node CableTray.ByLines.
Solution: MEPOver package isn’t enough, also ı have to load rhythm package.
Thank you so much
Hi, Appreciate if you can advise why the Revit not able to show cable tray . my Dynamo scrip indicated cable tray, by line .
On the ‘Element.Types’ node you should select CableTrayType instead of CableTray
Thanks . it worked
@T_Pover Can you Help me?
Yes: do not use the output of the element.name node as that is a string value, but instead use one of the actual conduit element types
Thank you very much!!! Now it’s working
