I want to design a plugin which asks for number of grids and levels and their dimensions at the beginning of every new project in revit. Which language should i use to start with? C# OR PYTHON? Because i have to start with scratch in programming languages. Kindly help!
C#.
But if you are new to coding ⌠perhaps do create a routine in dynamo instead?
DataShapes has perfect input popups etc.
(because asking for numbers and dimensions wonât be the only thing your script will do âŚ)
Thanks thats a great help.
What is DataShapes? Can it help with creating poping up a window in start of every new revit project asking for number of grids and levels?
DataShapes is a package in Dynamo.
But no it wonât popup when starting a new project (and I assume with a new project only)
If you use the Dynamo Player you can create a zero touch routine ⌠all youâll have to do is press the run button. If that is not an option: C#.
Okay Pinter. Thanks a lot. I am gonna search a little bit on Dynamo Printer and get back to you if need help. Thanks again
A simple example using DataShapes. First image is the popup that you will see when running the script. The data entered in the popup can be used as you wish (check the node âWatchâ)
Wow. Thats so easy and useful. So all i need is to create a node group for grids and join these inputs you created to that group of nodes. Right?
Yeah pretty much.
Creating a grid uses a startpoint and endpoint.
So create a few lists with the data ⌠and you are good to go.
I think you should start with python because itâs easy to learn and use, below is a code example of two languages, actually writing code on c # is faster but clearing up on dynamo is really difficult for a novice.Good Luck !
I have created nodes groups for grids. just last thing; what do i need to get DataSheet platform and how to connect DataSheet inputs to my dynamo group? (which will eventually give me results on revit)
yes sir ive been meaning to lean python for dynamo scripting. will look into it. thanks.
I canât find UI.MultipleInputForm++
they have this old DataSheet on Package Manager on dynamo site, it doesnât have the nodes you displayed earlier. kindly help!
No not installed.
(Yes Data-Shapes*)
I have dynamo 0.9 by default when i installed revit 2017.
Which version of dynamo has Data-shapes?
Deinstall dynamo 0.9.
Use either 1.3.x or 2.x
(If you look on the menu bar: you see a tab named âpackagesâ. Packages are addins for dynamo created by awesome fellow users which make life easier.
Man i have been trying to install dynamo 1.3 for days now
1st problem- on dynamobim.org/download , DYNAMO REVIT asks to click a link DYNAMO BUILDS and find the revit versions fo4 2017-2018. But the link shows a list of 3 types of dynamo versions âcoreruntime2.0â âdynamoinstall2.0.exeâ âdynamorevit2.0.exeâ which file do i need here?
2nd problem- when i use Dynamoinstall2.0.exe or dynamorevit2.0.exe, the dynamo in manage tab of revit doesnât have any nodes on the left side. And its just frustrating. I found similar problems with other users on this forum but i swear nothing helped
I so exhausted, i just need data-shapes and its teasing me so much. Please help.
@uaftab.cem19 go to https://dynamobuilds.com/
In first section (most stable) look for:
2018-12-03T16:05:46.000Z 221792368 DynamoInstall2.0.2.exe
2018-12-03T15:53:22.000Z 249491712 DynamoInstall1.3.4.exe
These are for revit 2017 right?
