Amigo @john_pierson i think there is a bug concernant Settings of monocle, i have to load every time, even if i load the settings and then make save current settings to default path, is not the end of the world but it’s a bit annoying to load each time, can you check when you have time? by the way when you open a cours of C# oriented to make zero touch plug ins in Revit or C3D concidere me enrolled!! ![]()
I’ll take a look at getting those fixed when I’m back from parental leave. If you wouldn’t mind adding it to the GitHub for monocle as well?
And since you asked, this one is at the “John record the videos” stage. All of the scripts and curriculum are done. And I hope to have an announcement in a month or so. ![]()
Ey broo
, congratulations
enjoy the vacations then, i will post it in git hub as well!!, thanks for the info of the cours, i did’nt see at the first look, i will enroll me!! ![]()
