Hi Everyone
I just started with Dynamo since I moved from Access to manage multiple tables with no limit of information (over 255 types of Parameters) and I find Dynamo like the right tool for automatization.
Right now I have a basic excel sheet that contains a drop-down menu that selects “X” or NULL, what I want is to drag that information back to Revit via a Yes No shared Parameter for a room.
If the user of the excel sheet selects from the drop-down menu X, I want to write back to Revit a check in the Yes No Parameter from a selected range.
I think is possible to have an if saying "If from the cell A1 from Excel there is an X it means true (1), else false(0) and write back in the Shared parameter “Test1_YN”
I tried to create the following code but it gives me that the SetParameter ByName is false, I think is related that there is no clear selection from which room that information will be changed.
I would really appreciate your help
Thanks in Advance
Dynamo Roombook Test2.dyn (16.3 KB)
Samuel
