Bring to Front/Send to Back Detail Items
Following up on this old post: Bring forward / send back (detail items)
This was working for me up until today. Anyone have an idea what could have happened?
Bring to Front Break Line.dyn (20.1 KB)
Now when I run it, I get this error:
File “”, line 32, in
AttributeError: ‘FamilyInstance’ object has no attribute ‘ID’
The IronPython code is
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘System’)
clr.AddReference(‘RevitNodes’)
#Converting input from Dynamo to Revit
mylist = UnwrapElement(IN[0])
#Bring detail item to front in a transaction
for i in range(0,len(mylist)):
viewmatch = mylist[i]
v = viewmatch[1]
elem = viewmatch[0]
btf = DetailElementOrderUtils.BringToFront(doc,v,elem.Id)
OUT = btf
Can you show an image of the graph with the output visible from the list of items being fed into it? You may have something in the “view” that you can’t do this on and it is throwing this error.
I do have a view with no name, which is odd.
Tried it again with a new project with just two views and a different detail element. Still getting the same error.
Capture2
ETA: Figured it out. The detail item cannot be in a group if you want to “bring to front” or “send to back”.
Simplified it a bit and upgraded to Dynamo 2.0 but now getting error:
File “”, line 31, in
Exception: The element detailElementId is not a detail element.
Parameter name: detailElementId
Revised Python script:
#Send detail item to back in a transaction
v = viewmatch[1]
elem = viewmatch[0]
OUT = btf
