Hello All.
Is there any custom node people know of, that brings forward, or sends back, detail items? Or is it even possible? I’m currently working on a project with alot of detailing where this would be very useful.
greetings, Robin
Hello All.
greetings, Robin
Hello Robin,
I’m not aware of any custom nodes that deals with draw order, but it is possible with the DetailElementOrderUtils class in the Revit API.
This example uses draw to back, but just replace
stb=DetailElementOrderUtils.SendToBack(doc,view,elemIds)
with one of the other methods shown below:
Dynamo example:
The python script:
clr.AddReference('RevitAPI')
clr.AddReference('System')
#Converting input from Dynamo to Revit
detailItems = UnwrapElement(IN[0])
view = UnwrapElement(IN[1])
#Creating collection of elementIDs
elemIds = List[ElementId]([el.Id for el in detailItems])
#Send detail item to back in a transaction
OUT = stb
Is it possible to change the draw order for detail components in multiple views?
I tried modifying your code as attached:
bring to front.dyn (7.1 KB)
#collecting views
viewcollector = FilteredElementCollector(doc).OfClass(View)
#viewcollector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views)
views = list()
viewIds = []
for view in viewcollector:
if view.IsTemplate == False:
views.append(view)
for v in views:
#viewId = v.Id
viewIds = List[View]([v])
elemIds = []
for el in detailItems:
elId = el.Id
elemIds = List[ElementId]([elId])
#Bring detail item to front in a transaction
#for i in range(0,len(elemIds)):
for v in views:
btf = DetailElementOrderUtils.BringToFront(doc,v,elemIds)
OUT = btf
Sure it should be possible, but first you need a list of views and a corresponding list with sublists that contain only the elements (detail items) in each view.
OK, what’s the next step after that? I keep getting the exception:
Exception: The set detailElementIds contains one or more non-detail element Ids.
Parameter name: detailElementIds
Figured it out. Thanks for the help, Einar.
I’m sure the filtering could be optimized a bit, but this seems to work.
Python script:
mylist = UnwrapElement(IN[0])
for i in range(0,len(mylist)):
viewmatch = mylist[i]
v = viewmatch[1]
elem = viewmatch[0]
btf=DetailElementOrderUtils.BringToFront(doc,v,elem.Id)
OUT = btf
