@Yna_Db when you ran my code, did you run it on multiple (more than 2) views? I ask this because I’m speculative that the X and Ys are reordering themselves. I threw together a sample file from a project someone did as a practice exercise, and added a view set similar to what I am working with, and I am experiencing similar X and Y discrepancies in the output.
Drats, thank you anyway @Yna_Db - I will try to throw together a 2016 version when I have the time. If you have time at some point, I’d appreciate if you could see how the code runs on more than 2 views; no worries if you don’t have the time, I already am very grateful for you pointing me in the direction of the Transform property.
I do believe there is mismatching occurring with the output of views and the output of bounding boxes. Maybe someone might have some insight on the order of outputs from a Python code in general.
Thanks for giving it another try with more than 2 views @Yna_Db , mysterious results. It seems the views that are displaying incorrect bounding boxes have rotated section boxes because this is a circular building… I think this may be an issue but wouldn’t explain for the mismatching I experienced with my sample file… will do some more investigation during my lunch hour and report back.
Just verified: this code does not work if the section box has been rotated. I’ll look into whether or not I am able to obtain the rotation of a section box within the Python code before I obtain its bounding box element; I have a feeling this may be unobtainable from what I see in the API Docs. But any suggestions or points in the right direction are welcome Thanks all to have contributed already - and thank you @Yna_Db for helping me solve the initial problem of the z outputs not corresponding with the model coordinates!
