I dont understand why the “&&” or AND boolean operator is not working
when i feed 2 lists of Boolean values.
I need a list with both values true to be true and rest condition to be false.
Hi there,
You could use this python:
Cheers
i will try this
@lucamanzoni it worked for first time , and then later null values donno.
Hi @Preetesh_Magdum1 and folks around,
I’m currently running into the same problem, but with || operator. My code block works perfectly right on the first time, then return null result on the second running. By any chance, did you find a solution regarding your problem ?
Best,
Matthieu
Hi everyone! Same problem with either || and && operators. Has anyone found a solution?
You can find the solution above post. Use code block for faster operation.
