I’m looking to simplify this operation, as I want to be able to change the input list without modifying the code.
How can I compare the boolean sublists using the ‘Or’ operator in a more elegant way?
How about List.Flatten after your List.Contains and then Any.True
Welcome to the forum btw ![]()
OK, I’m misunderstanding what you are trying to do.
List contains is 4 lists?
And what are you getting at List.GetItemAtIndex?
Yes, List.Contains has 4 sublists.
I’m using Get Item At Index to separate the 4 lists and then comparing them with the Or operator.
This is a nice example of when Dynamo is better than Python.
Was fun to Python it tho. ![]()
It’s works! Thanks a lot!
