What am I doing wrong here with boolean mask filter the data seems to match up. If it’s the nulls is there a way to replace them with empty lists? As I would like to maintain my data structure.
You will probably need to use levels on the Bool node to get into the data deep enough.
You’ll need to clean up your nulls as well.
