Block to Revit Family
The Dynamo graph is designed to extract AutoCAD block references from a linked DWG file, filter them by name, and place Revit family instances at their exact position and rotation. While the logic and node wiring across the entire graph are 100% correct, the graph fails to place families because the Element.Geometry node is not extracting block containers (GeometryInstance). Instead, it is only exposing exploded, raw 2D primitives (Line, Circle, Solid).
you can use this node. you need to open the autocad application and access to autocad object from revit dynamo.
Very Much appreciated sir, I will try this one thanks
