Hi Dynamo users,
I’m trying to extract how much block references are drawn per specific layer. So I’d just like to have a list with the name of the layer in column 1 and the number of block references in column 2, but I don’t know how to do it. Does anyone have already done it or knows how to?
Nicolas
Hi @nicolas.fernandez,
A List.GroupByKey node is probably best for this.
- Get the list of BlockReferences that you want
- Use Object.Layer to get the layer name of each BlockReference
- Use List.GroupByKey with the BlockReferences as the list and the layers as the keys
From there you could use List.Count to get the number of BlockReferences in each sublist.
He @zachri.jensen ,
Thanks for your reply!
I’ve tried it, but it still doesn’t work… I would like to have different lists by their name, so that the counting would give 4 of a layer and 1 of the other. Here is a screenshot of my script, maybe you could see what to do.
I think you have the inputs swapped.
