Block.Export node
I tried to export some blocks from one drawing to another .dwg with Block.Export node. My result was that it exported block objects, not actual block itself. But reverse operation with Block.Import node worked well - it delivered block into new drawing as it was in base drawing. I thought these nodes work similar with reverse direction, but seems different behaviour. Or is there some issue with Block.Export node?
It’s working fine, Block.Export works similar to WBLOCK, if you try that command it does the same thing.
