BimorphNodes V6.0.0 Released: Revit 2025 + 2026 Support
Dear Dynamites
We’re pleased to announce the release of BimorphNodes V6.0.0 which adds support for Revit 2025 and Revit 2026. The package supports Revit 2020 (2019 should also be supported for anyone still using it!?) through to Revit 2026.
FYI: Installing BimorphNodes
  • Due to the way BimorphNodes V6.0.0 is loaded (to support multiple versions of Revit), if you install BimorphNodes via the package manager it won’t automatically appear under the Add-ins menu in Dynamo (don’t worry, it is installed successfully). To see it, close/re-open Dynamo - you’ll only need to perform this action once; every other launch of Dynamo will always load it.
  • If you see warnings during installation about BimorphNodes being compatible with newer versions of Dynamo and Revit, ignore them; the package handles compatibility concerns itself.
Release Notes
BimorphNodes V6.0.0
  • Added support for Revit 2025 and Revit 2026 / Dynamo 3.x.
  • Backwards compatible with Revit 2020 ~ 2024 / Dynamo 2.x.
awesome news @Thomas_Mahon !
Thanks @john_pierson !
Thank you very much, Thomas! Your package is one of the few that is relied upon so much!
Cheers @john.gray great BimorphNodes is assisting your workflows!
Release Notes
BimorphNodes V6.0.2
  • Fixed an exception thrown by Sheet.Duplicate when ‘Duplicate Views’ was set to true + any view had a read-only parameter.
