Not sure if this is the right forum but I haven’t found any troubleshooting elsewhere.
When running the script I received the warning from the snip below, I uninstalled and reinstalled then the script ran, but the following day the error came back.
I will try reverting back from V5.X of the package to V4.X to see if that makes a difference.
Thanks, this worked although I’ve run into a different issue where the BIMorph node cannot run without using the node from the package to collect the elements.
The final script is a basic MEP reticulation vs Wall identification process to place a penetration request, I believe there’s other nodes although I’d ideally like to use BIMorph as I find it the easiest to work when the other models have the wrong internal origin, although I will go search for them now.
