As described in the title I’m getting this warning when I try to use the mencioned node. I’m trying to get the intersection between lines in the open document and solids from a LinkElement. Has anyone had this problem?
Thank you in advance!
That’s generally an indication Revits usless geometry engine cant represent the Solid using ASM. If that is the case, then it might be a showstopper.
Can you post the link file with an element exhibiting the problem which reproduces the problem?
Ok. I’m sending the teste project (Project.rvt), the linked file (Structure.rvt) and the dynamo file.
ClashDetectionCarol.dyn (22.0 KB)
Project.rvt (352 KB)
Structure.rvt (3.0 MB)
Cheers, I’ll take a look and update the thread when I get some time to investigate.
Thank you a lot!
