I’m new to Dynamo and I’m following “The Anatomy of a Definition” video and as I set up the Reference Point Revit does not correspond to any changes I make in Dynamo. I see the point in Revit but that’s it. Since this video was made with Vasari and older Version of Dynamo – are there changes in the newer versions and other work flows with Revit instead of Vasari?
We would use Dynamo for MEP, so is there a way to create Pipe/Duct in Dynamo?
Is it possible to have access to thermal properties for example u-value/thermal mass from elements in Dynamo?
Thank you.
lh
