Hello guys, I’m quite new in revit esp revit structure. I’m trying to put beams on top of pile-cap-2 Pile, but when I put 2 beams near together, they seems to join each other. How could I solve this problem, thanks guys.
Hi @hcmutkhanghaxuan,
Select the beam. at the end of the beam there will be a blue dot. right click on it and select disallow join. Or you can use this node from BIM4Struct Productivity package.
Thanks so much, bro.
If it is resolved your problem please accept it as a solution.
