Beam length
Hello, I want to obtain the real length of the beams (discounting the columns with which they intercept), I have not been able to achieve it for the inclined beams, any recommendation. Thank you.
MET-CA_Vigas_Perimetro.dyn (74.4 KB)
Could you also upload the rvt file?
It does not allow me to upload the file, it weighs a lot
What I want to obtain is the real length of the beam. (Discounting the columns with which it intercepts)
A+B+C
If you have the b and h as properties of the beam (which I expect you do).
Take the sum of the volumes and divide by the area.
Nodes that will help you are
Element.Geometry
Geometry.Volume
List.Sum
i think would you like.
Yes, that has indeed been the solution I have always had, but I tried to change the method when I had to develop a beam that was not rectangular and was also inclined. for now I have created a beam section area parameter and I do the division of the volume over the area.
That length is not the same when crossed with a column
split the beam at the collumns
make 3 different beams
Get the location line of the beam and split it with the geometry of the beam, then rally the total length. I believe this will account for the slope but can’t test.
How can I divide the line with the geometry?
Geometry.intersect
Thanks!!..
