I am trying to turn on Room Calculation Point of all families in my revit project. However, It is impossible to finish this task by dynamo.
Is there any advice about using python to do this?
thats a family issue. I would recomment you save all your families in a folder library. And open/close them to activate this option in the family! and that reload all of them…
crumble is a package for dealing with that. or you do it by hand if you have less then 100 families.
Thanks for your advice. I already downloaded the Crumple package, but I still have to open each family to turn on the Room Calculation Point toggle many times…
please try my script:
please put all the doors family in that folder
import os
clr.AddReference("RevitAPI")
app = uiapp.Application
dir = IN[0]
files = []
for file in os.listdir(dir):
if file.endswith(".rfa"):
files.append(os.path.join(dir, file))
for p in files:
opendoc = app.OpenDocumentFile(p)
ownerfamily = opendoc.OwnerFamily
param = ownerfamily.get_Parameter(BuiltInParameter.ROOM_CALCULATION_POINT)
TransactionManager.Instance.EnsureInTransaction(opendoc)
param.Set(1)
TransactionManager.Instance.ForceCloseTransaction()
opendoc.Close(True)
OUT = 1
Thank you. I tried your script, but some errors appear.(I am new on Python)
my script works on cpython but not ironpython,
here is the script which works on ironpython:
import os
dir = IN[0]
files = []
for p in files:
param.Set(1)
opendoc.Close(True)
OUT = 1
Could you tell me the function of this script?
before
after
toList = lambda x : x if hasattr(x, '__iter__') else [x]
doors = toList(UnwrapElement(IN[0]))
class FamilyOption(IFamilyLoadOptions):
def OnFamilyFound(self, familyInUse, overwriteParameterValues):
overwriteParameterValues.Value = False
return True
def OnSharedFamilyFound(self, sharedFamily, familyInUse, source, overwriteParameterValues):
return True
opts = FamilyOption()
for d in doors:
familydoc = doc.EditFamily(d.Symbol.Family)
ownerfamily = familydoc.OwnerFamily
TransactionManager.Instance.EnsureInTransaction(familydoc)
param.Set(1)
family = familydoc.LoadFamily(doc, opts)
OUT = 1
Amazing! I just tried windows category, It is work!
“for d in doors” This sentence is only for door category
I am wondering why it is work for other category.
it’s just a variable name ![]()
the script works on door and windows (they have calculation point)
Oh, understand. Thanks again for your help!
please mark it solved ![]()
