Hi, trying to make a batch render script using dynamo. I can find a lot of nodes for cloud rendering but struggling to find any for rending a few views using your computer over night. Can anyone point me in the right direction?
hi van man
there is a multiple render add in for revit available here https://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
it maxes out at revit 2016.
it will work for revit 2017 if you task switch to revit 2016 and back to 2017 to fool its version checking.
if i was to try and do it i would just use word’s visual basic and use sendkeys commands
ie rr for render and the other shortcuts… it wouldnt be as fancy
I came across this addin before but couldn’t get it to work. Gave it another go and now its working! and working with 2017 with your in-genius little tip! Thank you very much for the reply!
Well it was working. Now when i use it. I can hear my computer make a ting noise. Like the add in is failing to lunch something
