Batch Exporting Parameters from Multiple .RFA Files to a Single Excel Worksheet
I am attempting to export parameters from multiple .RFA files in a batch process to a single Excel worksheet. However, I’ve encountered an issue: the data from consecutive RFA files is overwriting the previous entries, as it starts from Row 0 every time. How can I ensure that the rows are populated consecutively in the same Excel worksheet when exporting data from multiple files using Dynamo?
Also,I am doing it in Revit 2021 for DataTypes as it supports the ParameterType Enum.
I have attached my DYN script and would greatly appreciate assistance from the Dynamo community!
Feel free to share any additional details or clarify specific requirements, and we’ll work together to find a solution! :blush:
@GavinNicholls
@MaxHue
@c.poupin
Family Parameter and DataTypes Export.dyn (38.4 KB)
Collate the data in rows in a single run instead by opening/reading/closing each family doc, then write all of that to Excel. Dynamo does not append to excel, it rewrites the file generally.
I’ll be adjusting my Crumple nodes to achieve this workflow in a month or so as currently a lot of my familydoc nodes don’t support one/many relationships for docs.
Thanks a lot. I will explore this workflow. :slight_smile:
In case you don’t want to open all the familydocs at once and keep using the current script logic, you could open the written excel first (if none found use an empty list) and append the parameters to the existing list.
This might not be an elegant solution though.
I found the solution. Thanks :slight_smile:
To show the upcoming nodes in my package and how much easier they will make it, I’ll give a sneak preview. I’m still working on the return trip (set parameters by value etc.). It’s quite tricky as some values such as elements don’t make it naturally in/out of Excel, so I’ll need to introduce some syntax to my workflow when it comes to Element Ids and missing parameters by document.
Looks very promising!
I am looking forward to the new realase !! :slight_smile:
Hi @GavinNicholls
Do you have any news on this script?
Kind regards,
Willem
They are added in the package and sample scripts here show how to use them:
Tested in revit 2023 and 2024 but havent had a chance to run 2025+ testing/updates. Some users have reported to me there are issues in 2025 so not sure if they will work there.
thank you @GavinNicholls
I am going to take the time to test this.
I would like to make an inventory of a very large collection of loadable and system families.
Has somebody ever tried to make a decomposition tree that reflects the relations of nested families , e.g. in Power BI?
thanks for sharing, what’s the best way to get the files and use them? is there package that includes all things that work. or do I download all files seperately? or something else
I made a course showing how they all work here that is free, and updated nodes to work in 2023-2026.
