HI,
Is it possible to get link model Wall elements base Constraint as a list name?
Look like
- List
- 0 List (BSM)
- 0 Wall
- 1 Wall
- 2 Wall Etc
- 0 List (F01)
- 0 Wall
- 1 Wall
- 2 Wall Etc
- 0 List (BSM)
HI,
Look like
Thanks for your help @Alban_de_Chasteigner
I am getting error, Please check the attached images.
Model in-place walls don’t have a parameter Base constraint.
Check what kind of walls you have.
Can you add your revit test file ?
Some of your walls don’t have the parameter Base constraint or are maybe in a group.
You don’t have the same levels in your host file as in your link.
So use Element.Level from Clockwork.
wall.dyn (7.7 KB)
