Revit 2017.1.1
Dynamo 1.2.1
Using Archi-lab nodes in graph (on 2016.12.7 build).
Graph goes:
- Get bounding box from {3D} view Section Box (which is showing extents of entire project).
- Create geometry from that
- Get all levels (and level above)
- Create geometry for each “level sliver.”
- Get bounding box for each piece of level sliver geometry
- Create Axon View for each, with Eye, Point, Target, and BBox.
The last step is all thats not working: It creates all the views, but they:
- Have no Section Box enabled
- Are not cropped to the Bounding Box at all (they show the extents of the entire model)
- Are Locked (Locked Orientation = 1), and not an editable parameter
Did i miss the point of this Node entirely, such that i am misusing it? Graph and sample model attached.
(Tons of thanks to John Pierson, for getting me this far. Im not enjoying sucking at this. I mean, im enjoying it, but not that im sucking at it.)
Parallax Team-01-Project Prep-Construction-3D Coordination-Create Export Views by Level-Step2-2.dyn (25.3 KB)
Parallax-01-Coord-Level Views-Sample-R17.rvt (424 KB)
