Hi.
I am trying to use the ‘AxonometricView.ByEyePointAndTarget’ node. The views are created as expected but the problem is that there is no output once created. That is, I can’t use the output to then drive other commands. Does this have something to do with transactions?
If it feed the output ‘AxonometricView’ into a Python node it will work/run. But if I feed the same output into a standard Dynamo node it is an empty list.
Any ideas?
