Hello dynaos,GetSetParameter.dyn (15.4 KB)
my task was to combine comments with the revision number in the comments. It works very well! in my script.
BUT! when i do my script severail times, it is adding the revisionnumber again and again!
How can i avoid that? I would like to have always the actual number of the revison.
the “rerun” should replace the number not add+!
KR
Andreas
Your probably best to generate some way of creating rules/filtering within your script.
EG if max length is 5 character after the additional element has been added, then you filter out all revision elements that have characters prior to then adding the parameters together.
comment = IN[0]
number = IN[1]
for i in comment:
if int(comment) > 4:
x = i.replace(number, ‘’)
OUT = strings
I did something like that, but it doesn`t work, I can count my letter, I can split my strings but i got not deeper! My idea is to replace all caracters after the 4th index by the revisionnumber - but how.
Where is the point where i need a integer@level and when i work with strings direktly.
Can i use codeBlock? I can delete strings but i have to count them! Can say delete all after the 3[index]
I tried without python code … it is still manualy but it would work to reverse the string to his origin!
Can i put it in a if sentence, maybe true take “in” false take out
right now is writing “function{}” in my comment node
