Hello all,
I am trying to alter a Python script a little bit.
The script overrides dimension values which works great.
I want to edit the script so a user can choose wether the script: overrides the value of the dimension, Adds a value below the dimension, or adds a value above dimension (dim.ValueOverride, dim.Above, dim.Below)
IN[6] was apointed for this and is called ‘positie’
If i change ‘dim.ValueOverride’ to ‘Positie’ in line 24 of the script, nothing happens.
I bet this is just a very simple issue that starts and ends with my lack of understanding of Python…
Anyone who can help me out?
Attatched screenshot below for clarification:
# Enable Python support and load DesignScript library
# Functions
def getForm(dim, brick, brickN, seam, seamN):
val = round(dim.Value * ftmm)
x = str(int(round(val / brick)))
if val % brick == seam:
form = x + brickN + " + " + seamN
elif val % brick == brick - seam:
form = x + brickN + " - " + seamN
elif val % brick == 0:
form = x + brickN
form = str(int(val // brick)) + brickN + " + " + rest
dim.ValueOverride = form
return form
if isinstance(IN[0],list):
allDims = UnwrapElement(IN[0])
allDims = [UnwrapElement(IN[0])]
brick = IN[1]
seam = IN[2]
brickN = IN[3]
seamN = IN[4]
ftmm = 304.8
rest = IN[5]
Positie = IN[6]
forms = []
for dims in allDims:
if dims.Value == None:
form = []
for dim in dims.Segments:
form.append(getForm(dim, brick, brickN, seam, seamN))
forms.append(form)
form = []
form.append(getForm(dims, brick, brickN, seam, seamN))
forms.append(form)
OUT = forms`Preformatted text`
Two problems:
You’re defining your variable, Positie
, after calling it in the defining function. Variables should always come first.
You’re providing a string. You cannot use a string as code. Rather than providing “the code” you want, you’ll want to use a switch to determine which code you run. I’d advise something like “Override”, “Above”, and “Below” for the three switches. Then you create three separate loops for
if Positie == [switch]:
[supporting code]
so that the ValueOverride code runs when you supply the “Override” string and the other functions run when you supply their respective switches as well.
Thank you Nick, for your very clear explanation!
I have changed my script with your suggestions and it worked on the first try
Thanks again!
Glad to hear, however, I misspoke a bit. I missed that you were defining your variable within a new function.
The variables that you define in your function are not the same variables that you use to call that function (even if they have the same names). So it actually didn’t matter that your function came before the input variable was defined - they were being considered separately. This also means that your function wouldn’t have updated anyway. For this reason, it’s best to use different names when defining the function and calling it.
That doesn’t actually matter when you write separate loops for the different conditions, but I thought I’d clarify.
I think you have lost me unfortunately…
I am really really new to python and used a script I found on this forum
Would yo mind describing what you mean with a screenshot of the script perhaps?
I would like to understand what you are saying but it’s rather hard without visual aid…
Please only if you don’t mind to do so! You have already helped me out a lot
Hopefully this quick example proves my point:
Here’s what you’d expect. I define the function with inputs val1
and val2
and also call the function with the same inputs.
If I define the function with inputs val1
and val2
but call the function with val2
and val1
my output matches the called function, not the original inputs of the definition. This is because the defined inputs are only used as variables when defining the function - they’re essentially placeholders. The order of the inputs is what matters, not the name.
You can best see it here, where the defined function uses val1
and val2
but the called function uses a
and b
. Variables a
and b
are defined for my code when I call the function, val1
and val2
are just for the definition.
Thats a very clear example!
Thank you very much!!
