I’m trying to automatically renumber the Mark field in all instances of a certain family (Parking).
There are some problems although:
a) The GetFamilyParameter node doesn’t return the Mark field, just Type Mark (as it should). How can I get the Mark field from the output list from Element.Parameters? Even with ‘Type Mark’ in a String node, it doesn’t work.
b) Using the Element.SetParameter.ByName, I’ve connected the entire list of elements (Parkings) with the result of a Number.Range node, and with ‘Mark Type’ as a string. However, the function isn’t working:
No parameter found by that name.
Element.SetParameterByName operation
I’ve tried with the previous GetFamilyParameter output Type Mark, but it also doesn’t work. I know that I’m linking a ‘Parameter’ output in a ‘parameterName’ input, but throught a Parameter.Name operation it isn’t working even if they are both strings.
I know it is a simple question and that it would be very easy task on other softwares (GH, for example), but I’m not getting it at Dynamo.
Any hints will be welcomed. Thank in advance.
File: Numeração Vagas
