Dear Dynamo experts,
I am attempting to create much more versatile tag families that allow the end user to selectively show/hide tagged parameters and do a few changes to the font styles with dropdown menus for each category. Much of this I will need to find a way to automate using Dynamo due to the sheer amount of visibility variables, see explanation below. Unfortunately, I cannot seem to figure out how to use Dynamo in the family creation environment. What I really want to know, is it possible to mass-rename parameters and alter text labels in Dynamo? I currently have vanilla Dynamo installed, no packages or addons.
In the screenshot below, the user primarily uses the “Area“ variable as a dropdown menu for font styles (including the choice of “-“ which hides the Area label completely) which is actually a dummy nested family that does nothing. A list of valid styles is defined as instance variables so whenever the dummy nested family is equal to an instance variable, some other visibility variables are activated, showing the relevant text in that certain style. Fortunately, there’s a gimmick with Tag parameters, where instance-based variables are completely hidden from the user, so I could use them to do the “dirty work“.
In total there are 3 different font sizes and 4 different font styles (normal, bolt, italic, underlined) per font size plus 3 different alignments (left, centered, right), which gives us 36 different labels that are selectively shown, based on user setting. So far, I’ve got it fully working for the “Area“ parameter of the room and I would like to do the same for all the other room variable types. Due to the sheer amount of variables (at least 50 for each shown category), I would have to resort to Dynamo to be able to manage this task.
This is what I have in mind:
- Save copies of this room tag .rfa, one for each type of paramater that should be displayed.
- For each .rfa, replace the “Area“ label with something else
- Rename the parameters.
- At the very end, copy all the contents from all families into the tag family. The resulting family will likely have 500+ instance-based parameters that are all hidden and the user sees perhaps 50 parameters (99% repetitive), so it should be easy and versatile to use.
I’m attaching the .rfa as-is so you get the idea what I want to achieve. Any help on this would be greatly appreciated!
Littera Rum Arial.rfa (468 KB)
