This is going to sound really dumb, but how do I do that exactly? =)
I appreciate your time and effort to help.
Taking it down a diverted quick path, it woul dbe easier if I knew what room number each list represented. I should be able to incorporate a different âobservationâ node or set of nodes that will tell me that correct?
I also know that I have some shared nested families that I will want to remove from the counts as well.
-Using Element.Name to provide a Key. The elements are then Grouped based on the Keys (at this point you need to be mindful of list levels and list management).
-The Elements in Room/Space node uses the same list structure as All Elements of Category, it just adds another level when it sorts through the elements. For this reason, you might not want to List.Clean, as the lists will stop aligning.
-While I know that some packages offer tools to collect nested component information, I havenât actually worked with nested information (maybe someone else can chime in). Consider looking through the most popular packages as a starting point, the nuance will be in what you want removed and how easily retrievable the information is.
I have a couple of project items I am working on but will give this a shot in the next day or two and let people know if it turned out. I will share the completed graph here once itâs complete as well.
Thanks again for your help so far!
So I havenât had a chance to get back into this yet. I will though and I will give an update then⌠=)
Hello again. It has been a little while I know but I am finally getting back to this.
To reassess where I am at: here is my latest graph. It seems to be getting the info I need, it is just not setting my FU_Counts parameter in the families. I am no dummy but it seems that the graph isnât complete enough for it to do what I am looking for. I do not believe it is counting the families in the room and it definitely isnât telling Dynamo what value to set the parameter to in any element at this point. I really hope you can continue to help me figure this out. I would really appreciate it if you could. =)
I cannot attach the sample test project file I have been using now so I can email it to you if it would help. FYI
I am still looking for some help on this. @john_pierson would you have some time to help me with this by chance?
