Automatic Tagging
Hey guys,
So, I’m trying to make a script that allows me to auto-tag all the families in my project following certain conditions. Basically, it finds the best distribution for the text.
So far, I’ve been able to make the text rotate according to the dimensions, shrink or enlarge, and add line breaks.
Now I’m trying to take it to the next level. First of all, I don’t know why when I switch to a section view in my “Views” node, Dynamo doesn’t do anything. It will only work if I close the program and run it again with that node already set, but in that case, I can’t switch back to my floor plan without going through the same process.
Also, in a section view, most of the families are not completely visible, so I would like to add a condition to the script where it finds the largest visible “square” that the family can show and then fits the text in there. Any ideas on how to achieve this?
AUTO-TAGGING.dyn (182.8 KB)
if you use DynamoPlayer it’s works ?
Increase the depth of your solids (so that they overlap), then perform solid subtractions.
The first problema was related to Element Binding, apparently if Dynamo detects that it already exists a note created with that script it will not create another one even if it has different parameters, the solution was this python script:
import math
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
# Inputs from Dynamo (Same order as the native node)
views = IN[0] # view
locations = IN[1] # location
texts = IN[2] # text
alignments = IN[3] # alignment
note_types = IN[4] # type
keep_readables = IN[5] # keepRotatedTextReadable
rotations = IN[6] # rotation
# Helper function to ensure all inputs are iterable (lists)
def to_list(obj):
if hasattr(obj, '\__iter_\_') and not isinstance(obj, str): return obj
else: return \[obj\]
views = to_list(views)
locations = to_list(locations)
texts = to_list(texts)
alignments = to_list(alignments)
note_types = to_list(note_types)
keep_readables = to_list(keep_readables)
rotations = to_list(rotations)
# Match the length of all lists to process multiple notes at once
max_len = max(len(views), len(locations), len(texts), len(alignments), len(note_types), len(keep_readables), len(rotations))
def pad_list(lst, size):
if len(lst) == 0: return \[None\] \* size
return lst + \[lst\[-1\]\] \* (size - len(lst))
views = pad_list(views, max_len)
locations = pad_list(locations, max_len)
texts = pad_list(texts, max_len)
alignments = pad_list(alignments, max_len)
note_types = pad_list(note_types, max_len)
keep_readables = pad_list(keep_readables, max_len)
rotations = pad_list(rotations, max_len)
notes = []
for view, loc, text, align, n_type, keep_read, rot in zip(views, locations, texts, alignments, note_types, keep_readables, rotations):
try:
    view_id = UnwrapElement(view).Id
    \# 1. TEXT TYPE
    if n_type:
        type_id = UnwrapElement(n_type).Id
        type_id = doc.GetDefaultElementTypeId(ElementTypeGroup.TextNoteType)
    options = TextNoteOptions(type_id)
    \# 2. ROTATION (Dynamo sends degrees, Revit uses radians)
    if rot is not None:
        options.Rotation = rot \* (math.pi / 180.0)
    \# 3. ALIGNMENT
    if align:
        align_str = str(align).lower()
        if "center" in align_str:
            options.HorizontalAlignment = HorizontalTextAlignment.Center
        elif "right" in align_str:
            options.HorizontalAlignment = HorizontalTextAlignment.Right
            options.HorizontalAlignment = HorizontalTextAlignment.Left
    \# CREATE NOTE
    note = TextNote.Create(doc, view_id, loc.ToXyz(), text, options)
    \# 4. READABILITY (Keep Rotated Text Readable)
    if keep_read is not None:
        param = note.get_Parameter(BuiltInParameter.TEXT_ALIGN_KEEP_READABLE)
        if param and not param.IsReadOnly:
            param.Set(1 if keep_read else 0)
    notes.append(note)
except Exception as e:
    notes.append("Error: " + str(e))
OUT = notes
Working now in the second part of the solution
Formatted and minor refactor of code (untested)
import math
clr.AddReference("RevitAPI")
def to_list(obj):
    if hasattr(obj, "__iter__") and not isinstance(obj, str):
        return obj
        return [obj]
max_len = max(map(len, map(to_list, IN)))
def pad_list(lst, size=max_len):
    if len(lst) == 0:
        return [None] * size
    return lst + [lst[-1]] * (size - len(lst))
# views, locations, texts, alignments, note_types, keep_readables, rotations
inputs = list(map(pad_list, map(to_list, IN)))
notes = []
for view, loc, text, align, n_type, keep_read, rot in zip(*inputs):
    try:
        # 1. TEXT TYPE
        if n_type:
        if rot is not None:
            options.Rotation = rot * (math.pi / 180.0)
        # 3. ALIGNMENT
        if align:
        # CREATE NOTE
        notes.append(note)
OUT = notes
