Just wondering if it’s possible to detect when a view has been affected by a change since the previous revision, whether that’s a model change, note added, detail lines changed etc. If so, would it be possible to automatically add a revision cloud to that view/sheet? Would be a neat way to pick up all changes since an issue, which sheets are affected etc.
You’d need to compare the two versions of the view, otherwise you’d have way too many clouds. You might want to look into BIM360 to help automate this as it’ll automate much of that comparison process.
I see. Thanks mate.
