Dear all,
I want to share the final definition for cable design inside cable trays.
I’m uploading also the family usde for 2D drawing
Cables3.dyn (57.4 KB)
FP_100_GY_DL.rfa (212 KB)
Have a look to this video for how to use it
Next step will be in order:
- Cable tray size
- Supports calculation according to the weight/type of cable and automatic placement
- Modeling of Conduits
- Connection with warehouse and SAP
- Convert all of this into a Plugin
Thanks to the forum for help[ing me.
Cesare
Hi, I downloaded the files and Can’t use because there are custom nodes, is there a way of you sending these or a way of using this file. brill work by the way and thanks in advance
kevin
Hi Cesare,
I’m trying to use this definition with Revit 2017 and Dynamo version 1.3.3, but i’m having some issues.
Could you share the custom node CurvesToPolycurve?
Thanks you so much!
Good afternoon. I would like to know if there is any topic with information like this for Revit 2023 and Dynamo? I want to do something very similar to what was presented in the topic and would like more information. If possible, would you have other examples?
