Automatic adding pipe tags to my sheet (help)
My name is Mike and i am very new to dynamo and made this, but its not working and i dont know whats going wrong.
Im trying to make that it will automatic tag pipes that are longer then 0,5m (50cm) in my sheet.
i dont know where i can put my family types (the tag i want to use) so it will automatic use that type of tag.
can anyone please help me and explain what im doing wrong.
Hi! For what I can see, this ootb node for placing tags doesn’t require Family Type input. I suppose it will place default pipe tag type, and then you can change it, in Dynamo as well.
If you want to control family type of the tag, I would recommend you to use nodes from Genius Loci package for creating independent tags
