I saw a post online about Automate viewpoint for rooms. It can create 3D view for each room in Revit and open in Navisworks. it has the room viewpoints ready. When I try to follow the scipte, it shows the error “The parameter’s storage type is not a string”. Would you mind helping me with this situation.
Thanks !!
Hi Kevin,
The error says it all. The parameter storage type is double.
Thanks Kul.
I added a level.elevation to get the right storage type but it shows “Dereferencing a non-pointer” Does that mean I shouldn’t put level under string node?
Show us all the values of each node.
That’s because your list contains “null” or empty values. Use list.clean to remove those.
