Automate point cloud plane and clustering with Python
Hi
I need to share with you how to automate point cloud segmentation by use python 3 in dynamo
I use the pythone code created by Florent Poux, Ph.D. and used in inside dynamo python3 node
To automate point cloud segmentation and 3D shape detection used multi-order RANSAC and unsupervised clustering (DBSCAN).
“Open 3d” python packedge was used in this example and the sample is loaded from the Florent Poux example
Getting started — Open3D 0.14.1 documentation
Ramiz Mohareb
enramiz@yahoo.com
https://medium.com/towards-data-science/how-to-automate-3d-point-cloud-segmentation-and-clustering-with-python-343c9039e4f5
import random
import numpy as np
import open3d
import matplotlib.pyplot as plt
filepath=IN[0]
import numpy as np
import open3d as o3d
[Point_Cloud.dyn|attachment](upload://zpv8LTaRTHJfMHGL7phUZJS3XZy.dyn) (42.1 KB)
segment_models={}
segments={}
inliers={}
inlier_cloud={}
max_plane_idx=20
Outt=[]
pcd = o3d.io.read_point_cloud(filepath)
rest=pcd
for i in range(max_plane_idx):
    colors = plt.get_cmap("tab20")(i)
    segment_models[i], inliers = rest.segment_plane(
    distance_threshold=0.01,ransac_n=5,num_iterations=10000)
    segments[i]=rest.select_by_index(inliers)
    labels = np.array(segments[i].cluster_dbscan(eps=0.1, min_points=100))
    candidates=[len(np.where(labels==j)[0]) for j in np.unique(labels)]
    best_candidate=int(np.unique(labels)[np.where(candidates== np.max(candidates))[0]])
    rest = rest.select_by_index(inliers, invert=True) + segments[i].select_by_index(list(np.where(labels!=best_candidate)[0]))
    segments[i]=segments[i].select_by_index(list(np.where(labels== best_candidate)[0]))
for j in range(max_plane_idx):
    Outt.append(np.asarray(segments[j].points).tolist())
o3d.visualization.draw_geometries([segments[i] for i in range(max_plane_idx)]+[rest])
OUT = Outt
Hi RMohareb, would you so kind to share the dynamo code used for that ilustrations? Thanks in advance. Best regards
Hello. Thanks for this. What format was your point cloud file? PTS?
Hi @bayowindapo yeit is pts file you can export it from Recap
I thought so. Thank you!
