Autodesk.Revit.DB.UnitType.UT_Length
Hi!
Just a noob question :slight_smile:
I’m in trouble with those lines of code from a script written by learndynamo.com
getDocUnits = doc.GetUnits()
getDisplayUnits = getDocUnits.GetFormatOptions(Autodesk.Revit.DB.UnitType.UT_Length).DisplayUnits
Does anybody know how to solve this? I’m working on Revit 2023.
Thanks!
UnitType is no more. It was replaced with ForgeTypeId.
Use GetSpecTypeId()
https://www.revitapidocs.com/2021.1/64822a98-a253-3300-cdbb-17973687878f.htm
Hi @dgeorge
here an example
import sys
#import Revit API
clr.AddReference('RevitAPI')
#Get Important vars
UIunit = doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()
nameUnit = LabelUtils.GetLabelForUnit(UIunit)
OUT = nameUnit, UIunit.TypeId
Thanks so much! The script just ran fine over those lines :slight_smile:
I have another error, at line 34… I probably missed something:
import sys
#import Revit API
clr.AddReference("RevitAPI")
curves = IN[0]
views = UnwrapElement(IN[1])
heights = IN[2]
output = []
getDocUnits = doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()
getDisplayUnits = LabelUtils.GetLabelForUnit(getDocUnits)
for curveList, viewList, height in zip(curves, views, heights):
	**height = Autodesk.Revit.DB.UnitUtils.ConvertFromInternalUnits(height, getDisplayUnits )**
	tempList = []
	for curve, view in zip(curveList,viewList):
		viewCropManager = view.GetCropRegionShapeManager()
		cLoop = viewCropManager.GetCropShape()[0]
		cLoopCurves = [x.ToProtoType() for x in cLoop]
		PointA = cLoopCurves[3].EndPoint
		PointD = cLoopCurves[3].StartPoint
		curveMP = Curve.PointAtParameter(curve, 0.5)
		if Geometry.DistanceTo(curveMP,curve.EndPoint) < Geometry.DistanceTo(curveMP, PointA):
			PointA = curve.EndPoint
		if Geometry.DistanceTo(curveMP,curve.StartPoint) < Geometry.DistanceTo(curveMP, PointD):
			PointD = curve.StartPoint
		PointB = Point.ByCoordinates(PointA.X, PointA.Y, PointA.Z + height)
		PointC = Point.ByCoordinates(PointD.X, PointD.Y, PointD.Z + height)
		LineA = Line.ByStartPointEndPoint(PointA,PointB).ToRevitType()
		LineB = Line.ByStartPointEndPoint(PointB,PointC).ToRevitType()
		LineC = Line.ByStartPointEndPoint(PointC,PointD).ToRevitType()
		LineD = Line.ByStartPointEndPoint(PointD,PointA).ToRevitType()
		curveLoop = Autodesk.Revit.DB.CurveLoop.Create([LineA, LineB, LineC, LineD])
		viewCropManager.SetCropShape(curveLoop)
		tempList.append(view.ToDSType(False))
	output.append(tempList)
OUT[0] = output
OUT[1] = nameUnit
OUT [2] = UIunit.TypeId
try to replace
by
height = Autodesk.Revit.DB.UnitUtils.ConvertFromInternalUnits(height, getDocUnits )
and
OUT[0] = output
OUT[1] = nameUnit
by
OUT = output, nameUnit, UIunit.TypeId
