I try to create personal room management class in Python using Dynamo Node. I use FilteredElementCollector in separate node to collect rooms. The tests show that as long as the room exists in Collector’s node, it is an Autodesk.Revit.DB.Architecture.Room class object. However after moving it to another node, it immediately becomes Revit.Elements.Room object.
Because of that I have troubles with using some of the methods (i.e. getting, setting parameters).
Why is it like that? What am I missing here?
Thanks.
