Auto dimensioning Columns not parallel to grids
Hi All, May I know if there is any way to auto dimension the columns which are not parallel to grids, @sovitek , can you please let me know if you have come across any such instance, Thanks in advance
the circled column for example
How would you manually dimension that column?
By picking the centre point of the column
do you mean center columns to the closest grid ? is so find the columns reference…i like genius loci for that kind and like openmep closest grid node and use closest point node…but can be done with ootb as well
Yes, the one which is not parallel to grids on either X or Y direction , by making use of openMep, i can get the closest grid but since the grid reference and column reference for this is not parallel to each other , the node “dimension by reference” is not giving the desired output
hmm do you have a small rvt you can share then we can take a look
clmn.rvt (7.2 MB)
Dunes_Columndimensioning Single.dyn (86.4 KB)
Please find the uploaded rvt and dyn file, Thanks
hi @kotyalgirish4 something here seems to work…just a fast exemple
Thanks for the quick response @sovitek , will follow this approach
