"Attribute error" 'list[object]' object has no attribute 'CropBoxActive'
Hi all,
I am trying to assign crop box to floor plan views using bounding boxes.
In the script below, I am using View properties in the API to apply the bounding box. However, it reflects “Attribute error” ‘list[object]’ object has no attribute ‘CropBoxActive’.
Any help to diagnose is appreciated.
# Enable Python support and load DesignScript library
clr.AddReference('RevitAPI')
newBB = IN[0]
views = UnwrapElement(IN[1])
output = []
views.CropBoxActive = True
views.CropBox = newBB
output.append(views)
# Place your code below this line
OUT = output
Hi @JHJHJHJH,
You have a list of one view with the node FloorPlanView.ByLevel so you have to iterate over the element in the list :
newBB = IN[0]
output = []
for view in views :
	view.CropBoxActive = True
	view.CropBox = newBB
	output.append(view)
OUT = output
The function Cropbox expects a BoundingBoxXYZ (Revit Boundingbox).
@Alban_de_Chasteigner Thanks for your help Alban! :slight_smile:
